Well you have so many ways to move on I'm not sure where to start. Lets start with the fact that it was able to update so I would think that means it has access to the internet. If from the panel you change it to developer mode and go back to the main screen it will show an ip address at the top. If it can't connect it uses some weird ip address - I think 192.264... which is the kind of failure address.
If you have a phone or ipad or laptop you can put the printer into wifi config mode. There are instructions somewhere but basically the printer will be a hot spot. Then you go to your phone/laptop/ipad and look at wifi access points and one will say something about ultimaker. Connect to that, open a browser and you can configure your printer to tell it which network to use, and what the password is for your wifi.
Thirdly you can use ethernet cables and just connect directly to your network. I have ethernet wired all over my house so I use that for one of my UM3's and wifi for the other.
And finally once you get all this working I recommend you go to your router and set it up so your um3 gets a static ip adress. Meaning the address will never change from here on out. I found that to be a better experience especially since I ssh into my printer a lot.
Thanks for the reply. I read somewhere else to delete the printer in Cura and select a new one. I did this and after fiddling with the WiFi setup it finally connected after the third setup round. I don't dare to touch the network now to try the LAN cable again.
Yes, I have already set a static IP in the router and the faulty IP address you are looking for start with 169.254.xxx.xxx
Now I'm having other problems with material setup over network... I will post a new one for that.
// Thanks.
gr5 1,872
