Another one suffering for ABS printing noob-ice
I'm just printing normal boxes, bellow you can see two separated attempts.
I've tried bed temps from 70-130 extrusion from 240-255 diferent flow settings, turned off the fan, and nothing seems to work.
This last complete print, is perfect on the higher layers but the bottom ones are incredibly strange as you may see.
https://www.dropbox.com/sh/erzwmmnmc4mjmoi/B4aK5dbJJP
gr5 2,156
If your bed isn't flat you can compensate in several ways. One is to use a thicker bottom layer. This is fine for most things. Another trick is to use the "raft" setting. But this will make the bottom layer look pretty bad and is even more likely to look bad on an ipad case (but for most things it doesn't matter). You could also choose either of these settings and print the ipad case sideways.
Personally for an ipad case, I think .2mm layers would look better.
