Hi there
Has anybody a clue on how to solve this issue ?
Thanks
David
Hi
Is there anybody out there having the same issue ?
Thanks
David
Unfortunately, this is by design. Cura has material-specific quality profiles. If you select a material for which there are no material-specific quality profiles, Cura does not make them up for you.
Hi ahoeben
Thanks for the info.
If I create a custom profile for the material, it should show up in the manager. Currently it is not the case, that's the issue.
Is it related to the install ?
I am also experiencing this problem. After installing the latest update the print profiles are all gone, even my customized ones.
As a side note, my Ultimaker 3 also struggles to print any sort of infill now, at least with Ultimaker brand transparent PLA.
V3DPrinting 10
BTW exporting materials from my previous install and importing again in my fresh install didn't worked.
I don't know if it is related.
