Why does Cura relentlessly try to create a file in a directory that does not exist?
rgelb
Posted · Why does Cura relentlessly try to create a file in a directory that does not exist?
For whatever reason, Cura (even when it's not doing anything and is sitting idle in the background) relentlessly tries to create a file in the C:\Windows\CSC\v2.0.6\namespace\RT-N56U.
Directory C:\Windows\CSC\v2.0.6\namespace does exist but RT-N56U folder does not. \\RT-N56U\TwoTB also happens to be a share that I am accessing (mapped to the Z:\ drive).
Why does Cura need to create a file there? And it does so relentlessly, over and over again. My computer physically slows down because of it and File/Open operation on Cura is so slow (probably because of this).
5a33413fe4b13_2017-11-2615_54_17-ProcessMonitor-Sysinternals_www.sysinternals_com.thumb.png.34a068b7a9cbb1bbb94332a19abc2c1a.png
    What version of Cura is doing this? Does it happen continuously while using Cura, or only when opening an Open/Save dialog?
    Do you use the "offline files" functionality in Windows?
    As i never heard of the Windows\CSC combi before (and I'm pretty sure that this isn't something that we hardcoded), i just googled this. So yeah, ahoeben seems to be onto something, as it's about the offline files functionality from windows itself.
    Posted (edited) · Why does Cura relentlessly try to create a file in a directory that does not exist?
    Yes, it's offline files and I've turned it off.  Still, Cura beats on a network mapped drive I have every 5 seconds.   Note in the image:
    I did figure it out with help of some folks.  It's the "Removable Drive Output Device Plugin".  https://github.com/Ultimaker/Cura/blob/3.1/plugins/RemovableDriveOutputDevice/WindowsRemovableDrivePlugin.py#L50
    The implementation has some issues:
    1. It loops through all the drives.  It should only be looping removable drives. There is a SO question about this.
    2. And it shouldn't be looping at all.  The app should register for notification of insertion/removal of USB devices to see if removable drives are present.
      I did this several years ago to detect insertion/removal of USB headphones and the method was pretty reliable.  I would contribute the code but it was in C#
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 11 replies
