SOLVEDmy UM3 Extended is experiencing multiple errors after being moved to a new location
Posted
· my UM3 Extended is experiencing multiple errors after being moved to a new location
I cannot say about the leveling issue, but the other two issues could easily be the result of the move. Not so much damage as more like a torsion pull on parts that may have slightly pulled a cable to two loose. The frame is flexible and can twist and pull a bit.
Also, I have not moved or damaged my printer, been printing along merrily and I have had the "detected movement outside of print volume..." error twice in the last month with the latest firmware upgrade. I have also seen the error reported in other threads by people who upgraded. Not sure of the specifics.
Posted
Have you checked if all connectors are still well inserted? Just every connector you can find? Gently (!) wiggle it and push it back on. Also visually check if everything is still aligned well and no corners are damaged from rough handling.
After moving mainframe computers in the 1980s (they had many 21" racks then, see the photo), it was standard practice for us to open the cabinet, and to reseat all print boards, and all flatcables, from the very first to the last. Because they would shake loose during transport on a truck. This solved 90% of problems caused by moving.
Posted
Thanks, will definitely check and secure all the connections tomorrow once I bring in my screw driver set. At the moment it's around 3 hours in and still printing, fingers cross it'll keep going while I sleep.
We don't often release an alpha version of Ultimaker Cura... So what's different this time? This Alpha contains such a huge slicing engine overhaul that we really need your help!
We wish to celebrate and honor the innovators that push forward the field, technology and world. We opted to not present it as a competition or ranked list. Every innovator has earned his spot on that list in their own way. We also look at the 3D printing industry as a whole and not limit the list to those only using Ultimaker.
kmanstudios 1,074
geert_2 462
kc-li 0
