Can you show a photo or screen shot of what you are talking about please? Is the problem visible in layer view or is it fine in layer view but you can see the problem only after you print it?
i have tryed to upload a print screen but it is not working in cura and i cannot add the file in this forum either
So imagine a box without a bottom and a top 50*65 mm one side z+50 mm opposite side z+10 mm what is happening is the first 10 mm in Z is filled with a raster but it is supposed to be a single wall when i remove the infill the wall on the first 10 mm in Z is made thicker also when you look in the layer display the first 10 mm is green on the inside the rest upwards is dark red
gr5 1,512
