I am using an UM 3 with a 0.8 mm core. I will upload the pictures , I am having some issues with air-gaps between layers.
DidierKlein 729
Air gaps is called under extrusion and can be caused by many things
Speeds, low printing temps, inconsistent filament etc...
kmanstudios 1,117
If it is ferro magnetic, it has to be abrasive as heck. And metal fills present their own challenges. under extrusion is also a problem as the heat transfers faster and higher up the filament and can cause clogs that cause it to have difficulty passing the filament through.
On 5-12-2017 at 6:52 PM, EMDL said:Printing core suggestions needed
As mentioned the metal particles will kill your CORE nozzle quickly.
Unfortunately Ultimaker does not have any solution on the market for this atm. I hope they someday will bring us a 0.6 RUBY CORE.
For now the only solution for the UM3 comes from 3DSolex, with the "everlasting" nozzle ( lol, I would not take that literally )
http://3dsolex.com/product/um3-hardcore/
http://3dsolex.com/product/everlast-hardcore-nozzles/
I have not tried the "everlast" myself, but as said it's the only UM3 option atm. For now the best/cheapest option is printing abrasives on an Ultimaker2. Here you have the option to simply throw away the worn out brass nozzle, or get a RUBY nozzle; http://olssonruby.com/
kmanstudios 1,117
That would depend on the printer. If you put your printer information in your profile, it makes it easier.
At least in the description.
