Cura 3.1 menus not at mouse location
JSleeman
Posted · Cura 3.1 menus not at mouse location
In order for me to click on a menu or a dialog box I have to go about 1/8" below the menu/box to select it. This is a new laptop that runs at a really high resolution (3840x2160), I drop to 1080 and the problem persists.
    I had the same problem running on 1800p resolution.
    For me, it was a long trial and error for an easy fix.
    If you are running on windows right click on Cura shortcut -> Properties -> Compatibility -> TICK the box: Override high DPI scaling behaviour -> From drop down just beneath choose: Scaling performed by: SYSTEM
    It also worked for AutoCAD and Creative Cloud by Adobe.
    That should fix it. Or at least it did for me :)
