I'm guessing the bottom of your model only touches the build plate in a few sparse locations. Maybe you think the bottom of your part is flat but it isn't - if this is the case try unchecking the thing that keeps you from changing Z and move the part down a little (set Z to maybe -0.2mm) to see what happens.
So to post a screenshot first save it locally on your hard drive - then click the 2nd from right most icon (image gallery). then go to the second tab (upload) and drag your picture on.
Yeah, that makes sense. This is an STL and I am unable to re-generate it because it's not my design.
I changed the Z position (top left corner of screen if anyone else is having the same issue) and it worked a treat! I did not know about this! That's why we come to the forums! Great help!
Thank you.
gr5 2,070
crumbsPenfold 0
Thank you.
