Posted · V1.5.7 Ultimaker original
Greetings,
I am having trouble identifying the current path to the extruder motor #1 on the pcb. I burned up the PS when I tripped the circuit, and after running several programs on the mega, uploading the latest Marlin firmware, and reassembly I have found that everything works as normal with the exception of the motor for the filament extrusion (no voltage).
I would rather repair the circuit than replace it as I am on a disabled veterans pension. Any input or advice will be very appreciated.
thank you in advance,
Pantera09
