Quote
you can reach maximum build volume by turning off brim and skirt, and set "travel avoid distance" to 0.
Please note that in the corners, there's also keep-out zones for the bed clips, the camera and the switching bay (all indicated with gray zones in Cura.
Thanks tomnagel. I've set Build Plate Adhesion Type to "None" and Travel Avoid Distance to 0mm which reduced the gray zones, but still unable to slice.
Edited by stevesy
tomnagel 123
