Cura 3.1 Build plate levelling doesn't work
HansUnland
Posted · Cura 3.1 Build plate levelling doesn't work
Hi! Today I updated From Cura 3.0.4 to Cura 3.1. Using the new version unfortunately the build plate levelling does not work correctly. The plate stops with z-axis about 10 mm before nozzle. After reinstalling Cura 3.0.4 everything works fine. I'm working with an Ultimaker Original+. What could be wrong with 3.1? Or do I need to change anything.
