@upatamby it is controlled by a mix of ultimaker cura settings and firmware configurations as far as I know.
Personally I would prefer a simple line like everyone (prusa, makerbot) does to prime the nozzle as I had some problems at the start too. It's just once in a while now.
If you don't want the prime blob you can disable it in cura. Search for: "Enable Prime Blob". If disabled I recommend to use a few skirt line or a bigger brim to prime the nozzle.
Maybe Ultimaker will change or add more options for priming in the future but this can take a while due to varios reasons.
My idea would be a tap under system called advanced -> priming strategy -> prime blob, prime line, maybe even something else.
upatamby 8
Cura version is 3.1.0.
Printer is Ultimaker 3 Extended with firmware 4.1.4.20171204
