it is a feature in Marlin firmware, and is quite common
http://marlinfw.org/docs/features/lin_advance.html
kmanstudios 1,117
Seems to me that the profiles would do that for you. Make your changes and save that to be applied in the future. Or create a small, generic project file to load and just bring the models into it.
Why confuse things even more?
1 hour ago, kmanstudios said:Why confuse things even more?
Because Linear advance, JKN advance or pressure advance (however you want to call it) will improve especially the corners of your printed objects.
Have a look/read here: JKN advance documentation
I remember seeing pictures of bad corners in another thread. You can for sure go without but if you are looking for perfection you probably want to use it.
I don't think the UM2 series will get such an update but maybe the UM3 ( )
added another link
kmanstudios 1,117
Your original posit was for Cura to add extra settings so you would not have to hunt for these things every time you print. That was answered. I am not disputing what linear advance can do, just the bit about wanting specialty settings so you can click one button for just one feature set, when you can already do that with the current setup. I would rather them solve other issues than adding new buttons just to make things easy for one instance.
1
eldrick 64
It would be good if you would tell us what "Linear Advance" is, and why one might want to use it...
