yellowshark 153
Yes your analysis is right and course @gr5 's comments are right too, as one would suspect. But if it were me I might be inclined to turn the front two screws 1/4 turn anticlockwise to bring the front of the bed up to meet the rear. Like gr5 I too like to have the brim that thin, especially on parts with a large surface area, to ensure it sticks securely to the bed. Anyway whatever you do just remember what that part of the brim looks like now, then if you have adhesion problems in the future try adjusting the distance so the brim looks like it does at the rear now.
1
gr5 2,069
wow! We have a didierk and now a deiderik both from Belgium. Actually didierk is now didierKlein.
Anyway I like my brim that thin. It means the part will stick VERY WELL!
But you can just turn the rear screw 1/4 turn clockwise to pull the rear of the bed down a little bit. I often adjust the 3 screws while the brim or skirt is printing on the bottom layer.
I don't like the auto level for many reasons. So I recommend disabling that. Also you should be aware that the glass probably isn't flat but the autolevel assumes it is and does a best fit plane. Hopefully a future version of the firmware will do a more complicated transformation to compensate for a more complicated glass surface. Anyway it may be that the best fit involves the rear center being a bit high as in your photo but the rear corners being a bit low (which is very common as typically the glass is thicker in the very center).
