Thank you very much for your suggestions, I'll go through them tomorrow and report back!
The printer is an Ultimaker 2+ which has gone through quite a bit of print time by now. I haven't done much maintenance other than keeping the rods mildly oiled and making sure it's calibrated for use, all parts are clean etc.
gr5 2,094
What kind of printer? It's the printer, not the slicer. Make sure the belts are of equal tension in X and Y and maybe calibrate and also make sure the X and Y axes are perpendicular. The most common problem on a UM printer would be that the two rods going through the head are not perpendicular. If it's a UM printer then push the head to the 4 walls and make sure the blocks hit at the same time. If not loosen some of the set screws and re align and then tighten the hell out of those set screws and double check. The symptom would be errors in the diagonal direction - in otherwords bottom left of the desk to top right would be a different diameter than the perpendicular measurement.
If X and Y are not exactly equal on your printer then you would get different distance in those axes instead.
Another common problem on the old UM originals was the pulleys were not colimated - in other words the hole through the pulley was not through it's center. This results in for example if the head is supposed to be moving at a constant speed it instead speeds up and slows down each time the pulley rotates once.
But you should also consider putting a shaft or hole in your disk so you can mount it on a drill or lathe and file/sand it down a bit while it's spinning fast to get it better. *and* also consider adding bits of glue or other weights to make it well balanced. I took apart an old cassette player recently and was amazed at the heavy round part that was connected to the capstan (the primary speed control shaft). Even though it spun kind of slow it had all kinds of last minute adjustments to make it perfectly balanced. And it was clearly made very accurately on a lathe at some factory yet they still had to drill out a few chunks to balance it.
