Posted · Unloading and loading material- No cancellation
Today i ran into a problem that took FOREVERR!!!!
My PVA filament got stuck in my drive gear
While attempting to reverse the filament out of the extruder, it wasnt coming out. When the gear was finished reversing, My machine then asked me to load the new filament, all while the filament was still stuck in the extruder and drive gear. so i had to turn my machine off and on. HORRIBLE FOR IT!!!!
There was no way to exit or cancel and home the head just like how my UM2+ have.
Does anyone else run into this problem? is this a firmware issue???
Love my Ultimaker machines I have 4 of them. Visited the lab in Utrecht where it all began and im forever team ultmaker!!
 yaaahoooo
    • foleybot changed the title to Unloading and loading material- No cancellation
    I raised this in another thread.  There are definitely certain processes that can use an abort option.  I've been forced to cycle my machine a couple of times because I couldn't escape a process.
    I don't let the machine insert nor remove filament automatically ever.  I just pull it out or slide it in by hand.  And then if I changed material (e.g. pla to abs) then I tell the machine afterwards.  Get the wedgebot - you'll find it the most useful thing to print for your UM3:
    https://www.youmagine.com/designs/wedgebot-for-ultimaker2
    So did you get it sorted out?  Did you have to remove the bowden at one end or the other?  Did you have to take the feeder apart?
    • Like 2
