Posted · Clean G-code to other 3D printer
Hi
Need some help whit some lines in the g-code i don´t want to be there when i save to file "g-code"
Is it possible to edit some ware in Cura 3.1  ?
I want only use my own start.gcode and end.gode to get Cura works to my older Malyan printer.
Example this code line in yellow colors i vant get deleted in Cura 3.1 every time i generate code.
Happy to get help, just testing Cura to work to my Printer.
    I have helped my self :)
    I found the script solution to get the g-code modified.
    If some els are searching this solution you get it in the post process plugin.
    Here is some example if you don´t want get out some line to g-code.
