gr5 - thanks a lot for your quick response - I tried it before - I even did it under Preferences -> Settings as I expected it probable somewhere outside Material - yep, I found couple of other "temperatures", but non of them was set to 210, when I made them visible - see the attached screenshot.
Edited by CraosThe 210 temperature in the start gcode issue is a known issue in Cura 3.1, and will be fixed in Cura 3.2.
kmanstudios 1,120
11 minutes ago, ahoeben said:The 210 temperature in the start gcode issue is a known issue in Cura 3.1, and will be fixed in Cura 3.2.
That may be why my petg prints came out badly as opposed to before.
I thought I mucked things up. Thanks for clearing this up!
For reference, here's the related GitHub issue: https://github.com/Ultimaker/Cura/issues/1296. Will indeed be fixed in 3.2.
gr5 2,094
I don't know the answer to your question but...
On your screenshot it shows "search...".
First make ALL settings visible, and then enter "temp" into that search box in your screenshot. Perhaps there is another temperature setting (I'm not sure).
