3DSolex Hardcore Temp Error
Posted · 3DSolex Hardcore Temp Error
I have an Ultimaker 3e and purchased a couple of Hardcore nozzles to replace AA cores to get faster prints.  I get max temp errors on both of the Hardcores randomly during and after prints. One of the cores is currently in the print head and I am unable to remove it as it trips the error before I can pull out the filament.  At first I thought it might have been some dodgy soldering on the printcore pcb but after trimming the spaces between the soldered connectors and the smaller connector on the side it the problem persists.  Could it also be the spring?  The tension of the spring on the Hardcores is much less than the original ones so maybe replacing those might give the core some more rigidity in the holder and sit better against the pins?
The original cores have worked flawlessly btw just the Hardcores are throwing temp errors.
I'm stuck please help.
    • 1 month later...
    Sorry I didn't see this until now.  The first thing to make sure - push harder on the clear part until you hear/feel it snap in.  You don't have to do this with the UM cores but the hardcores need a little extra push.
    Are you printing with the silicone rubber installed in the print head?  I was printing with a 0.8mm nozzle and 0.3mm layers and the silicone pad was missing and that got enough wind inside to make it so the core couldn't keep the nozzle hot (now that I think of it, that was a UM core, not a hardcore - still - the silicone rubber helps).
    It could just be a bad/intermittent temp sensor wire (or heater wire).  If it's the temp sensor wire you will also see the temp bouncing around.  If it's the heater wire it will cool a bit unexplicably and get heater errors.  Heater error and it's *usually* the heater.  Temp sensor error and it's always the temp sensor connection/wiring.  If problems persist you should ask the seller for a new hardcore.
    • 3 weeks later...
    Thanks for the reply. I Initially thought it might have been that so I pushed it in quite hard.  I've had two of these Hardcores for a few months now and the other Hardcore seems to be going OK after a firm push-in but one of them is still on the brink of throwing the error. How do I know this? The orange spikes in the graph below is the Hardcore reporting 700C for an instant. Not enough to throw max temp but enough to show the material compatibility warning on the display just like when a new printcore or material is inserted.
    Eventually I know this will turn into max temp errors after a while.
    My silicone pad is on OK I also print with 0.8 and 0.3 and sometimes with PETG it can get pushed around but I always make sure to re-seat it.
    I have tried desoldering the temp sensor on the back of the print core removing the connectors and resoldering the wires back on.  While I had it disconnected I tested the sensor by wiggling dropping and flicking it while hooked up to a multimeter.  Granted this probably isn't the best way to test I didn't have an oscilloscope handy at the time.  On the weekend I'm going to try a higher tension spring and maybe a shim behind the print core PCB to ensure the connections stay firm.  If it persists after that I'll lean more towards suspecting the PT100.
    700C would be an open.  Look at the gold contacts on the hardcore - you should see a dash.  A horizontal line where it's making contact in your print head.  It might be the line is too high or too low.  Or you might just have a bad temp sensor.
    These temp sensors are difficult to make even though the factories that make them make hundreds of thousands of them.  They can't use solder because normal solder melts at 200C and even high temp solder melts at 250C.  So they use some kind of tiny clamps.  Each time they heat and cool they expand and contract.
    I'd tell your reseller and send it back and get a new one.  3dsolex can take it apart and throw away the temp sensor and use most of the parts in your core for a new core.  Reuse is better than recycle.  Did you buy it direct from 3dsolex?  Or did you buy it from a reseller?
    i have the same problem, the AA hard core has worked half hour and now give temp error and  some times the printer don't recognize it and display slot empty
    the strange is that in the 3DSolex web page there in not a contact email !!!!!
    sales@3dsolex.com is the email you need Lorix.  Carl is sending me a new temp sensor as I can install it myself.  You may want to send yours back for a new one if you're having slot empty issues.
    thank you, i have sent now an email at Carl. I will inform here about news from Carl
    Lorix try tightening some of the bolts on the print head and see what happens.  I've just over-tightened the back two top side bolts and the bolt behind the print head that holds the PCB inside.  No open circuits on either print core for the last two prints.  I'm thinking these broke free of their thread lock and are causing the print cores to miss-align with the connector on the PCB.  The Hardcores are more susceptible to this because they are slightly different to the original ultimaker cores.  I'll let you know how it goes but this looks like it could be the problem and not the temp sensor itself.
    the problem was the PT100, i have contact Carl, that has send me the replace part in few time
    the wire was damaged, and probably after the first half hour with the high temperature the damage was irreversible
    Well at least yours was obvious lol.  Tightening the print head bolts has worked a treat so far.  I only get spikes upon heatup and cooldown from whichever hardcore is in slot one.  That corresponds to the left back bolt that was loose causing the print core to drop and the left most pin to slide off the print core pad at random.
    This thread is helpful to me, I've just inherited a hardcore throwing a problem.  I'd like to be able to measure and plot the temperatures and signals as you experts on this thread have.  How does one do that?  I do have a scope, but is this a matter of reading results from the motherboard, the core itself, or ?
    Thanks
    John
    The temperature chart from above can be requested from the printer:
    http://<ip_address>/info/temperature.html
    • Thanks 1
    Thank you!  I get the feeling the info directory is a place I should spend more time.
    Much appreciated.
    Cheers
    John
        • 4 replies
