Are you using mulitple monitors? This is know issue for multimonitor setups (including monitors attached to a laptop). see https://github.com/Ultimaker/Cura/issues/2326
A usable workaround:
Use Mesa-drivers for opengl instead of system drivers:
DisplayLink drivers in combination with intel drivers seem to often cause issues with white/blank windows ;D
thanks, this worked for me
On 4/23/2018 at 10:31 AM, geeky said:A usable workaround:
- Download the latest version (x86 or x64 matching your cura build) from http://download.qt.io/development_releases/prebuilt/llvmpipe/windows/?C=M;O=D
- Extract the *.7z (for example with 7zip)
- Rename the opengl32sw.dll to opengl32.dll
- Copy the opengl32.dll to your cura-folder
- Run cura: No more blank windows ;D
I created an account just to say thanks!! This worked like a charm.
Thanks Geeky! I had the white screen on updating to 4.4, and your workaround worked like a charm :)
I just wanted to put it out there that I had the same problem with 4.6.1 (oddly only on one computer). This fix worked like a charm.
hi, i've tryed this with 4.6.1Cura, it's doesn't work for me, i still have a white screen and a "Ultimaker Cura (doesn't answer)
i'm answer to myself , this solution work for me : https://github.com/Ultimaker/Cura/issues/7779
ahoeben 1,657
The blank window is the dialog that is trying to tell you that Cura has crashed, but it has a bug in itself so it stays blank.
What OS do you use?
Could you try Cura 3.0, or the Cura 3.2 beta that was released yesterday?
