Thermoelectric cooling
Posted · Thermoelectric cooling
Just wanted to know if anyone tried using a thermoelectric board to cool the hot end "cold area", these semiconductor boards can go down below 0C and are very easy to use, just plug the 12v supply.
it is possible to use a round one - http://www.ebay.com/itm/Annulus-10-26mm-TES1-04930-Thermoelectric-Cooler-Peltier-Plate-Module-C0503-/290891565455?pt=LH_DefaultDomain_0&hash=item43ba7d098f
did anyone tried it :)?
    You still need to cool the hot side of the peltier. Also, creating a larger than necessary temperature difference is counter productive IMHO. The hotend has to be able to dump even more heat into the filament to melt it that way.
