The TUNE menu on the printer tells the firmware called "Marlin" to adjust all speeds by that amount. So the answer is "yes". It also affects retraction speed, z axis speeds, etc. Each axis also has a max speed (typically 300mm/sec for x,y axes for example) and if the TUNE adjustment results in a speed over the max it will limit to the max speed instead.
1
1
kmanstudios 1,117
Going by Cura, in its menu selections of print speeds, there is a master print speed and then several others below that. I assumed that the manual speed adjustment you mentioned worked as a multiplier for all speeds as it does in Cura.
I could be wrong though.
