1 hour ago, GFlow said:Are you saying I should use a different hole on the box? like the one through the top and have the spool feeding the other way?
No I'm saying you can simply drill your own hole in the perfect position. As kman says, place the hole so the filament makes as gentle a transition as possible, eliminating any sharp bends. Eliminating as much friction as possible.
Maybe the hole through the top is in the right spot but maybe not.
If you have a drill and drill bits then how hard could it be?
kmanstudios 1,099
I choose the hole that makes for as straight a pathway as possible. Any additional angles or turns just adds to the friction.
