Hi Geert, I think of static but I would expect it to discharge and damage the board permanently, I also tried to flee the board outside of the box but nothing really happened, I will get a meeter and see whats actually happening, this could change my design somewhat or at least my material (if I can figure out these material profile thingies)
Dan
geert_2 560
I don't know Polymax, so I can't comment on that. But maybe you could also look into the opposite? Could it be that it is electrostatically charged too much, and that this causes malfunctioning? Most plastics charge up easily. This could especially be a problem if the board would contain CMOS or similar stuff, with open pins, or circuits with very high input resistances? If dust and little pieces of plastic debris easily get stuck on the model, it is probably charged up. Apart from other possible reasons of course, like a broken soldering, broken copper trace, or wire?
