Ultimaker 3
Cura 3.1
Start a dual extruder print, select Tune, change Extruder 1's material flow. Return. Go into Extruder 2, notice the material flow is now changed. If that's intentional, it doesn't seem like its a per-extruder setting. Did I do something wrong?
SandervG 1,519
Can you be a little bit more specific in your question/comment? Are you asking something, or informing us? What 3D printer are you talking about and/or what version of Cura are you using? Thanks!
