Hello,
Thank you for your reply. I went through the gcode and indeed the end structure looks very different:
Cura 15.x:
M107
G10
G0 F9000 X135.664 Y111.928 Z135.786
M25 ;Stop reading from this point on.
Cura 3:
G10
M107
M82 ; absolute extrusion mode
Does anyone know about some setting that would revert Cura 3 to the old behavior? I wouldn't like to have to edit all of my gcodes manually...
Thanks again!
gr5 1,877
I haven't had this problem. I usually use cura 15.04 for my Um2 but occasionally I need a cura 3.X feature and it's worked fine for me.
However I have heard the advice to add M25 to the end of gcode files for the UM2.
Supposedly that helps the UM2 know that you are at the end of the file? I don't understand it exactly.
