Compiling Ultimaker 2+ Firmware
killerb77
Posted · Compiling Ultimaker 2+ Firmware
I want to compile my own Ultimaker 2+ firmware.
It says this in the notes on github: “One time change: The UM2 made changes to the I2C driver. You will have to remove this driver function from the Arduino IDE by removing the TWI_vect interrupt routine in arduino/libraries/Wire/utility/twi.c, line 364 Note: when you compile the sources using the makefile you can skip this step.”
So do I just comment out or delete line 364 and that’s it?
    3 hours ago, ChrisRiddell said:
    Out of curiosity did you edit just the file "hardware\arduino\avr\libraries\Wire\src\utility\twi.c" as that's the only copy of twi.c I can find.
    arduino-0023\libraries\Wire\utility\twi.c
    Old version v23 of arduino.  It's the version suggested in the instructions.
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 15 replies
