Posted · Keep the Bed Temp. When Print is Done
In Cura, after the print is done, is there an option that allows you to leave the Bed Temperature on or do you have to manually re-adjust it? This would be very helpful because I need it to stay on when I need to print something else.
I do not think there is a setting in Cura to do this but I have not used vs. 3.n so I could be wrong. It is easy though, just add a command to the end of your g-code file; M140 Snn where nn is the temp. you want.
However, you may find you need the bed temp to drop down from the printing temp. so that you can easily remove the print from the surface. Better to wait 5 mins than damage your plate:)
    As @yellowshark said, keeping the bed temperature up once the print is finished is a recipe for damaging the print or your bed, maybe both.
    I've not seen such as option in CURA 3, but maybe I haven't been looking at the right places.
    I don't think you'll damage the glass any more than if you let it cool.  I could be wrong about this.
    But you *are* more likely to damage the print.  For PLA and ABS the bed is kept above the softening temp of the material meaning the bottom mm or so is quite soft and can be easily deformed.  For PLA you want it to cool to 50C before removing.  For ABS let it cool to 95C before removing.
    Most of the time I simply can't remove my models as long as the glass is above 30...35°C, or this would damage the model and decalibrate the glass bed. However, you can speed up cooling quite a lot by putting a 25cm desktop fan in front of the printer, as soon as it is finished.
    ...but one can imagine printers with swappable build surfaces and auto/active-leveling..., right? :p
    Yes, indeed. Buy a second glass, buy a cheap electronically controlled oven, and preheat the second glass in there when the other is almost finished printing...
