Ultimaker Community of 3D Printing Experts
Welcome to Ultimaker Cura 3.2 | Stable
  • Replies 170
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
A) I have NO virus issue. You just ranted about your favorite anti-virus program. B)Yes, you have very poor communication skills and this is coming from someone with Asperger's. For instance you
my 2 cents; Think it would be good to distinguish between the purpose of the video's. With a new release I would like a short snappy video quickly showing the new features, max a few minutes
Ok, bye.   Sorry guys for the inconvenience. Let's get back on topic.
Posted Images
Posted (edited) · Welcome to Ultimaker Cura 3.2 | Stable
Hi guys.
In "layer view" i just see "compatibility mode" instead of previous color scheme with 3 options, feedrate, material color, and line type.
I seen a flag in general settings about the "compatibility mode". It's referred to that (in this case it's not functioning.
Second question: where to find a manual (or an upgrade of manual) with the new functions?
Thanks in advance to anyone will help.
Herman
Edited by erman58
nowi try to restart the system after installation to see if the situation it's the same...
    Posted · Welcome to Ultimaker Cura 3.2 | Stable
    6 minutes ago, ahoeben said:
    How are you installing the plugin? It works for me using the Plugins -> Browse Plugins.
    I did it that way. I also have installed it directly from github to the plugin folder and, although the installation is made (as version 3.1 not 3.2), it actually does not work. It does not print when pushing "Print to octoprint" button
    That is the exact symptom you get when you install the 3.1 version of the plugin in Cura 3.2. I have only just come around to switching the github page to the 3.2 branch by default; before just now the default download would get you the 3.1 version of the plugin which is not compatible with Cura 3.2 (due to changes in the API between Cura 3.1 and Cura 3.2). Having said that, the official way to get the plugin is through the Plugin Browser or using a .curaplugin file.
    Please remove all versions of the plugin from your configuration folder (including any versions you have manually installed), and restart Cura. Then use the Plugin Browser to install the plugin and restart Cura. If that does not work, please upload your cura.log somewhere (dropbox, google drive, etc) so I can have a look.
    If you manually install the OctoPrintPlugin from git, chances are you end up with the plugin in a different folder than the plugin browser expects it, and it is possible that if you install an updated version with the plugin browser you end up with multiple versions of the plugin that fight eachother.
    Don't See colour scheme :(((
    Edited by mrSEADEMON
    @mrSEADEMON and @erman58: In the General preference page, is the option "Force layer view compatibility mode (restart required)" checked? If so, uncheck it and restart Cura.
    If that does not solve it, that means that your graphics driver tells Cura it does not support the features needed to show the "non-compatiblity-mode" version of layerview, and Cura can only display simplified layerview.
    thanks. I add start cura with Nvidia card and all work
    I have removed the octoprint plugin folder but I have the same errror when installing it from Plugin Browser. In fact, There is no Octoprint archive or folder for this plugin in the installation folder neither at github branch (https://github.com/Ultimaker/Cura).
    I am sorry but I can't find the requested cura.log. Please, where I can find it?
    Thanks for your support
    You should not need to download anything from github. Forget github for now.
    To find the log file, launch Cura and go to Help -> Show configuration folder. There's a file named cura.log in that folder.
    ok, Thanks again. Please, find here the requested cura.log file https://www.dropbox.com/s/gc5s5ln9u2bbgqe/cura.log?dl=0
    Could you tell me what files are inside C:\Users\Eladio\AppData\Roaming\cura\3.2\plugins\OctoPrintPlugin\ ?
    The following ones:
    DiscoverOctoPrintAction.qml
    LICENSE
    OctoPrintComponents.qml
    OctoPrintOutputDevice.py
    OctoPrintOutputDevicePlugin.py
    README.md
    __pycache__
    OctoPrintPlugin
    .gitignore
    __init__.py
    CMakeLists.txt
    DiscoverOctoPrintAction.py
    I thought that I have removed that folder but I did it from tin installation folder at C:\Program Files\Ultimaker Cura 3.2. Maybe I should remove them from this location also?
    Yes, that's what I've been trying to have you do ;-)
    Great. Now it works. I don't know what was the initial problem but after removing that folders and installing it from Plugin Browser (and activate the plugin plus restart the program), it works.
    Thank you very much for your support and your effort
    This is not stable at all.
    I installed it 6 times now. Each time it crashes some of my various higher end 3d software, or simply won't launch due to the same error I got for EVERY Cura version after like 2.1 or 2.3 and up until 3.1 ( which worked fine.. until now.. ) The error is related to win updates and service packs informing me that AGAIN, I need MORE service packs to run Cura 3.2
    YOu cats need to understand some of us out there simply can NOT keep adding service packs etc and altering our pipeline.. they often have compatibility issues with other 3d software. This can not keep being the answer for you guys. I can't keep ruining my career software so I can 3d print. This is obviously a prob with 3.2 as when I re-install 3.1 I have no issues.  Thoughts?
    Edited by VULCAN
    On 2/6/2018 at 7:51 AM, kmanstudios said:
    Oddly all my Avast installation did was to run a scan for malware, report it was safe and then say "It was a rare file and will be sent to HQ for further testing" and then let me install with no issues. The last time I installed with Avast I did get a pop up saying that the file was fine and added to Avast's clean list. Or, whatever they called it. But I did not have to create any exceptions.
    Edit, oh yeah, also, nothing popped up regarding arduino or anything else.
    Lose AVast for starters. It is garbage. No high end IT people use it at all. Mcaffee, avast, norton, all garbage and basically a virus in themselves. And they sell your info. Kapersky is the only true secure hold out. They won't sell their code to the US OR Russia where they are from. Most IT guys in my industry that requires an insane amount of legitimate system security use Kapersky for anti virus.
    The thought I have is that you are doing a rather poor job describing what your problem is, making it very hard to help you. This is your first post here, and I have no idea what you mean with "the same error I got with EVERY Cura version after like 2.1 or 2.3".
    I do share a house with a cat, but I am - in fact - human.
    typicall UM team response.. read it again.. and not my first post. QC better. If you want to help, help.
    did you miss this?
    Edited by VULCAN
    All you say is " The error is related to win updates and service packs informing me that AGAIN, I need MORE service packs to run Cura 3.2 ". I am sorry, that does not ring a bell for me. Unless you take a breath and take some time to be a bit more descriptive, I can not help you. If you just came to vent, and don't want my help, that's fine with me as well.
    I do spend a lot of time working on Cura, but I am - in fact - not part of the UM team.
    So why are you replying if you can't help? What is hard to understand about what I said?  What is descriptive?  I sent the error to UM.. what else? If you don't get that, you obviously didn't see what was happening with prev versions.. the same issues,,. what do you want ? Just to chime in? Ask me a question if you want to help...  Just telling me you don't like the way I talk isn't helping. When you need a product to work and you have spent thousands on it and the dev team keeps fixing things that aren't broken and breaking things that work, then maybe you can tell me to take a breath. I on the other hand have a job to do and don't have time for garb like this when it is billed as STABLE.
    Edited by VULCAN
    Is this descriptive enough? I had to do this thing called research to figure out that it was referring to wanting me to update to another OS or use more Service Packs.. I had to research that error just to find out that info.. so how much more descriptive would you like it hot shot since this is the only error I get? ( It doesn't let me view the "detailed crash report" ) before you ask..
    Edited by VULCAN
    Anyhow. I'll fix it myself like I have done with every UM and Cura problem so far. No sense in trying to get help.
    Edited by VULCAN
      • Ultimaker Transformation Summit
        On April 20 - April 23 we will host the Ultimaker Transformation Summit. Come talk to us via Live chat and get inspired by any of our relevant presentations!
        • 6 replies
      • New here? Register your Ultimaker for free 3D printer onboarding course
