The other question I have is regarding the Z axis itself - is the axis normally a bit loose? If I slightly wiggle the axis rod, I'll notice it will move a bit within the drive nut. Is this normal?
No. Not normal. I just wiggled my bed, the z screw, everything I could. I pushed the bed up and down at the front and back and side to side and twisted and spun the z screw and tried to move the z screw up and down. Everything is impressively tight. More than I would have thought possible looking at the design.
I remember assembling my bed and nothing fit. I had to file down almost every opening - the openings for the bearings, for the Z nut, the openings to let the plywood into slots. Everything was too tight. It took several hours just to assemble the bed because of all the filing (like sanding but faster) I had to do. I also had to add shims to space out the bearings far enough apart so it could fit onto the vertical rods the correct distance apart. Shims are just little pieces of wood to fill the gap so I could tighten the side arms to the bed piece nice and tight.
gr5 1,872
These jumps are in Z only? Not in X or Y?
