I installed cura 3.2 twice and every time I try to select my printer "monoprice select mini v2" it opens for a sec then closes the program. Any idea what could be happening? I am using windows 10 with the most recent updates if that helps
I noticed when I upgraded Cura today that anytime I tried to any the monoprice mini select, it would crash immediately. After digging around it looks like the problem is in the malyan_m200.def.json file. It is used for providing definiations for the MP mini select. To fix the problem edit \Ultimaker Cura 3.2\resources\definitions\malyan_m200.def.json
About 2/3rds of the way down there is a line
"material_diameter": { "value": 1.75 },
Change it to
"materia
