tinkergnome 929
9 hours ago, erodriguez said:After done a little 3d objects and save as 3mf file, the cura doesn't open it...
I tried it, and Cura opens your file without problems...
...but the 3D object is not little, it's extreme small - only 0.4mm - so it's a bit hard to locate on the screen....
Here is how it looks like, if i scale it up by 10000% or so...:
1
pbackx 11
I have never tried to open 3mf files in Cura, so I'm not sure if this is supported (some one else will probably reply with more details)
However, what you can always do is convert the 3mf into STL using 3D builder: https://www.microsoft.com/en-us/store/p/3d-builder/9wzdncrfj3t6
Next, you can open the STL in Cura
It's an extra step, but that should work.
Edited by pbackxLink to post
geert_2 560
Doesn't Paint3D have an export option to save as STL-file? First save in the native format, so you don't lose the design. Then export to STL if that options exists.
Otherwise, in addition to converting, you might also want to try other simple CAD programs? Maybe Tinkercad? I haven't tried it yet, but I heard that some schools use it. Maybe other programs too?
For kids of +10y, you might try DesignSpark Mechanical. It is more technically oriented, but still very easy to learn. And there exist a lot of good tutorial videos.
Google or Youtube for these programs, and watch a few demos, to see if they appeal to you, and to the kids.
