i change sheme to but no color line too!! win7 64
Edited by mrSEADEMONYou're still in compatibility mode. Please go to preferences -> general and switch to normal layer view mode (if your PC can handle that). Then the drop down for new color schemes becomes available (after restart).
It's the last checkbox in the "viewport behaviour" section. Disable it and then restart.
Then Cura has detected that your graphics card or drivers are not compatible with the minimum required OpenGL version (4.1?). You can still slice and use adaptive layers, you just can't preview the layers in Cura.
@mrSEADEMON, you can probably force Cura to use the nvidia card instead of the embedded gpu, and then the full layer view should be available.
1
Just now, ahoeben said:@mrSEADEMON, you can probably force Cura to use the nvidia card instead of the embedded gpu, and then the full layer view should be available.
thanks. I add start cura with Nvidia card and all work
Didn't know that trick, great it works now!
I think it is an intricacy of the nvidia "optimus" driver, since the embedded GPU is more than capable enough to show layerview (https://ark.intel.com/products/75117/Intel-Core-i7-4700MQ-Processor-6M-Cache-up-to-3_40-GHz, supports OpenGL 4.3). But at least it works now.
- 2 weeks later...
On 2/8/2018 at 9:24 PM, mrSEADEMON said:thanks. I add start cura with Nvidia card and all work
Newbie here, how to add start cura with Nvidia card ?
Go to nvidia setting. Add cura to start with nvidia drivers
ctbeke 132
Compatibility mode doesn't allow other colors schemes. To see one of the 3 other schemes you have to switch to the normal layer view (if that's possible on your pc).
