In CURA the temperature is located in the MATERIAL menu.
You can also make a search for 'temperature' by using the 'Search...' bar right above all the settings and just under the 'Profiles' drop down menu.
1
Ok, my mistake, I misunderstood what you meant.
If it's not on the options, then it is not possible at the moment. And I don't think it would be really doable to print different models at different temperatures at the same time. The printcores would have to heat up and cool down all the time, which might be damaging in the long run, and it would also increase your print time quite a bit, as you'd have to wait for the heating and cooling of the cores.
You'll have to print your cubes one by one, changing the temperature manually.
ok. too much to ask.
as a retired programmer of more than 35 years, I know that if that per model option existed and it was non-null for ANY particular model, then I would set a flag to over-ride the print all at once option (no matter what it said), and put a pop up message to that effect, to "print one at a time".
but I only prepared one at a time, and changed the gcode to the temp that I wanted. It will work. But it would have been slicker to print all of them "one at a time" at different temperatures. Thinking about it, maybe I should change the gcode to NOT cool down in between, so I can print them faster.
There is a print one at a time option if you are not using more than one extruder.
kmanstudios 1,074
If you are using dual extruders, each nozzle will be listed by extruder number.
