Can I see a photo of the feeder when it's closed and ready to print? If you are new with this printer you might not be closing it properly (this is a common problem for first time users).
Is this your first time printing or have you printed 100s of parts just fine in the past?
With the nozzle at 200C and the feeder open such that the filament slides easily in and out you should push on the filament with about 5 pounds (3kg) force and see filament coming out of the nozzle. Does it squirt out just fine? If so the problem is at the feeder end and not the nozzle end.
If it does *not* feed well one test is to remove only the nozzle (while hot - anywhere 120C to 180C) and then let it cool to room temperature and then feed the filament through the head to see if there is a tight spot somewhere - it should slide through easily with the nozzle removed and everything cold. I suppose there could be some hardened left over filament in the head so maybe you have to heat the block to about 100C and that should be plenty warm enough to slide fresh filament through without making a mess. Once it starts passing through the head lower the temp and pull out the filament - you don't want it stuck in the threads. Then try again at temps below 50C (52C is the softening temp of pla).
foxxey 0
