thopiekar 8 Posted February 12 in Autodesk Inventor Plugin (0.1.5) (edited) Just reserving here this thread for questions between users, who are using the plugin. Additionally, feel free to add ideas for improvements, which are important for you as issues to the project page. Looking forward to stimulating and inspiring ideas! Thanks! Website: https://thopiekar.eu/cad-integration/inventor-plugin/ Current release: CuraInventorPlugin-0.1.5.curaplugin -------------------------------------- Installation guide for the .curaplugin files Plugin uninstallation guide -------------------------------------- Special thanks go to: @dxp for testing the plugin in its early stages! --------------------------------------- Edited February 15 by thopiekar Share this post Link to post Share on other sites
dxp 4 Posted February 12 in Autodesk Inventor Plugin (0.1.5) Hi @thopiekar well, it was impossible to load a (2017) Inventor file (named 170816P1-Demonstrator Innensechskant.ipt) "CuraInventorPlugin.CadIntegrationUtils.CommonReader.readOnSingleAppLayer [193]: Temporary file not found after export! (next file format..)" Tried 2 different files. The Preview worked, but importing failed. Log is attached. cura.log.um-forum.log Share this post Link to post Share on other sites
thopiekar 8 Posted February 12 in Autodesk Inventor Plugin (0.1.5) Ah, damn. I need to update the plugin because of some changes I made in the SolidWorks plugin. I added some features to a common application module and it looks like the Inventor plugin does not get these changes. Share this post Link to post Share on other sites
dxp 4 Posted February 12 in Autodesk Inventor Plugin (0.1.5) Oh, I'm your most patient (beta)-user... Share this post Link to post Share on other sites
thopiekar 8 Posted February 12 in Autodesk Inventor Plugin (0.1.5) Yes, you are and looks like you are already a good one Share this post Link to post Share on other sites
thopiekar 8 Posted February 12 in Autodesk Inventor Plugin (0.1.5) (edited) After uninstalling and reinstalling Inventor, as suggested by Autodesk during their beta program, something got broken. Can't test my own changes, but, in theory, the new package under the same URL should work now. PS: Btw, this is what I get here: Quote pywintypes.com_error: (-2147352567, 'Ausnahmefehler aufgetreten.', (0, None, None, None, 0, -2147024809), None) Edited February 12 by thopiekar Share this post Link to post Share on other sites
dxp 4 Posted February 12 in Autodesk Inventor Plugin (0.1.5) Quite an elaborate error message! So, I deleted the PlugInFolder under MyName\AppData\Roaming\cura\3.2\plugins and installed your Plugin again. No import - file not found. Same error. Hopefully your installation will be working soon! Cheers. 1 Share this post Link to post Share on other sites
thopiekar 8 Posted February 12 in Autodesk Inventor Plugin (0.1.5) (edited) Got it! Works now on my side. The issue was that I copied months before some articles from Autodesk websites, which are describing their API. What you can see on Windows as a quotation mark (which is fine for Python programming), can be also a "0x93" byte, which made the plugin crash. Good that I had Ubuntu installed on Windows, so I was able to look for the file, which contains the byte: Updated the plugin file again, but now it should work. PS: At least it opens part, assemblies and drawings using Inventor 2019 Beta2 now. Edited February 12 by thopiekar Share this post Link to post Share on other sites
thopiekar 8 Posted February 13 in Autodesk Inventor Plugin (0.1.5) @dxp Any success? Share this post Link to post Share on other sites
dxp 4 Posted February 13 in Autodesk Inventor Plugin (0.1.5) (edited) Nope. Still failing. Maybe wrong version? Edited February 13 by dxp images doubled Share this post Link to post Share on other sites
thopiekar 8 Posted February 13 in Autodesk Inventor Plugin (0.1.5) (edited) Nope, should be fine. Just redownload from the first post and install. Could you maybe send me your cura.log? The log could be very long, so it would be nice if you could remove it and then reproduce the bug. After that, the log should only include the relevant info. Additionally, is it possible to share this .ipt-file? Sending via e-mail is just fine On the other hand you can try these files, which I use to test the plugin: https://github.com/thopiekar/CuraInventorPlugin/tree/master/tests/Inventor Professional 2018 Just try to open them normally with Inventor before opening them in Cura, to make sure Inventor is able to open them at all. Oh, and which Inventor version are you using? Regards! Edited February 13 by thopiekar Share this post Link to post Share on other sites
thopiekar 8 Posted February 13 in Autodesk Inventor Plugin (0.1.5) (edited) On 12.2.2018 at 2:09 PM, thopiekar said: Just reserving here this thread for questions between users, who are using the plugin. Additionally, feel free to add ideas for improvements, which are important for you as issues to the project page. Looking forward to stimulating and inspiring ideas! Thanks! Website: https://thopiekar.eu/cad-integration/inventor-plugin/ Testing version: https://thopiekar.eu/download/CuraInventorPlugin-0.1.4.curaplugin Installation guide for the .curaplugin files: https://thopiekar.eu/cad-integration/solidworks-plugin/installation/#manual-install There was a common issue with the SolidWorks plugin. 0.1.4 is out! PS: Technical explanation: Edited February 13 by thopiekar Share this post Link to post Share on other sites
dxp 4 Posted February 14 in Autodesk Inventor Plugin (0.1.5) Hello, the plugin is working now, i can import *.ipt-files directly. Yippie! Cheers dxp 1 Share this post Link to post Share on other sites
thopiekar 8 Posted February 14 in Autodesk Inventor Plugin (0.1.5) 15 minutes ago, dxp said: the plugin is working now, i can import *.ipt-files directly. Yippie! Awesome! Share this post Link to post Share on other sites
thopiekar 8 Posted February 14 in Autodesk Inventor Plugin (0.1.5) (edited) Hey @dxp, are you experienced with custom exporting parameters in SolidWorks and Inventor? 3DS defines two values: "Resolution - Deviation Tolerance" "Resolution - Angle Tolerance" --> http://help.solidworks.com/2013/english/api/swconst/FileSaveAsSTLOptions.htm Whereas Autodesk defines four of them: SurfaceDeviation ( 0 to 100 for a percentage between values computed based on the size of the model ) NormalDeviation ( 0 to 40 to indicate values 1 to 41 ) MaxEdgeLength ( 0 to 100 for a percentage between values computed based on the size of the model ) AspectRatio ( 0 to 40 for values between 1.5 to 21.5 in 0.5 increments ) --> https://forums.autodesk.com/t5/inventor-customization/ilogic-stl-translator-specific-parameters-info/td-p/4418665 --> http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-25D24E28-7517-4903-8AEE-123F8C71A89E Do you have an idea how to translate the two values from Solidworks into these four? Or backwards from these four to the two of SolidWorks? Thanks! PS: Asked the same question in the Autodesk forums: https://forums.autodesk.com/t5/inventor-customization/bd-p/120 Edited February 14 by thopiekar Share this post Link to post Share on other sites
dxp 4 Posted February 14 in Autodesk Inventor Plugin (0.1.5) Hi @thopiekar, i'm using these settings: oOptions.Value("ExportUnits") = 5 'Millimeter oOptions.Value("Resolution") = 0 'High - muss hier stehen, sonst grottige Qualität Never tried "Resolution"=3. With "2" even the real prints had triangles where cylindric surfaces should be. So "0" was a good setting between file-size and quality. Autodesk has some more information about SurfaceDeviation and such stuff here: STL File Save As Options reference As for the translation - phew, that's to much of a guessing game for me. I would say "Resolution - Deviation Tolerance" = SurfaceDeviation and "Resolution - Angle Tolerance" = NormalDeviation but there is no time for further research as i have to do my engineering work Ciao! Share this post Link to post Share on other sites
thopiekar 8 Posted February 14 in Autodesk Inventor Plugin (0.1.5) (edited) Alright! Still, thanks for taking a look at it The plugin is using Resolution = 0 already: https://github.com/thopiekar/CuraInventorPlugin/blob/dcf51da34571bea5ed21db06063c906a6aa3a1ec/InventorReader.py#L178 https://github.com/thopiekar/CuraInventorPlugin/blob/dcf51da34571bea5ed21db06063c906a6aa3a1ec/InventorConstants.py#L12 However, I should care about resetting the changes I made, like in the SolidWorks plugin, because people could get angered, who are using settings, like export in inch. Edited February 14 by thopiekar Share this post Link to post Share on other sites
