Hey! The plugin has been updated for Cura 4.4+ and a bug has been fixed.
If the document (part, assembly or drawing) is already opened in Inventor, the document won't be closed anymore.
There was already a check for it before, which was (it seems) not fully tested by me. Therefore, the check gave wrong info and leaded to this issue.
Enjoy!
- 1
Top Posters In This Topic
27
10
6
3
Popular Days
Oct 10
11
Feb 12
8
Feb 14
5
Feb 13
4
thopiekar 27 posts
eried 10 posts
dxp 6 posts
DHQidiTech1 3 posts
Popular Days
Oct 10 2018
Feb 12 2018
Feb 14 2018
Feb 13 2018
Popular Posts
dxp
Quite an elaborate error message! So, I deleted the PlugInFolder under MyName\AppData\Roaming\cura\3.2\plugins and installed your Plugin again. No import - file not found. Same error.
dxp
Hello, the plugin is working now, i can import *.ipt-files directly. Yippie! Cheers dxp
tetrahedron
@thopiekar, Seems to be working again with Cura 3.3.1 and plugin 0.15. Using Inventor 2017 R4.3
Posted Images
michaelpond08 0
I really liked this plugin for the early versions of Cura! When I needed to make changes to a model, I could change the .ipt file, and just import that same file into cura. Instead, with Cura 4.4, I now need to make changes, export an STL file, and then import that file into Cura. It's an extra step, and it requires that I remember whether the STL files are up to the same revision as the Inventor part files, which isn't always the case.
Is there a plan to update this plugin to work with Cura 4.4?
