If the nozzle is clean (= if you can look through it from above after an atomic pull), and the feeder knurled wheel is clean, maybe it could be the teflon coupler? Have you checked if this white teflon coupler on the nozzle isn't worn out? On an UM2 (non-plus) this has to be replaced every couple of 100 hours, depending on materials and temperatures used. On an UM2+ is should live much longer, but not endlessly.
porsche1 0
Had the same problem and tried several different things similar to what you did. Finally I increased the hot end temp from 210 to 225 while it was printing and that seems to have done the trick. I also increased the build plate temp temp to 65 but I dont think this helped. I am using yellow pla.
