Hello,
My English is not good but I will try it next time
1
Hello,
As you say, what about making a negative, and then again positive of it?
Maybe it could be done as follows? First make a copy of the design, and only work on that copy, so you do not destroy the original. Then make sure your house has no gaps: so no open windows, no open doors, no open chimneys; all must be nicely closed. Put a box around your house, a bit larger than the house. Subtract the house from the box. This will give a complex thing, since all interior details will also be subtracted. But you also have the negative shell. Move the negative shell (box) out of the way, and keep it. Delete all the rest. Now you have only the negative shell, not the interior anymore. Make another box of the same size. Subtract the negative shell from the new box. And there you have a positive house in one solid block. Print with some infill as desired for mechanical strength.
If your software supports it, maybe an easier way would be to fill everything: select all, or select the shell, press "Fill", and hops, you have one big solid. Might work with some 3D-packages?
Guten Tag @Giuseppe Nagler,
Meshmixer has the option of taking the outer shell of a model.
Try to play with it.
I was just wondering why you cannot just turn off layers in your main cad package when you output for print. Am I missing something?
The problem is not to position elements in different levels, but to fill the cavities of the building unnecessarily with support material and I seek a method that makes the whole thing easy and quick; I do not want to have to model the building into simple shapes, if I have already modeled it in great detail, but I do not need that definition on a scale of 1: 200 or 1: 500;
I think that the sampling of such small details would make them disappear. If I am understanding you. I may be getting this wrong.
Now for basic interior support, If you have a floor, walls and roof with closed windows and doors, I would think it would not fill, but use its stitching feature to combine the specific components I mention into a perceived solid and just input infill.
If you could kick out one simple building with just those components as an STL file, I would love to check that out.
But, again, I may be missing the point after all. That would not surprise me.....
this house for examplepepetest-02.stl
I am going to look at the file you put out. But did you generate that from a CAD package? Just looking at the screenshot, it seems the layers (if they are separate) for the internal walls and such are still on. Basically an extruded 2D floor plan.
That would make things more difficult as it would not put doors and windows in like a 3D Package like Revit would.
OK...I am not familiar with that. But the reason I can see (again, only looking at the screen shot as I am finishing up something else) is that you have voids in place of the doors and such. i could be wrong and will check out the file this afternoon my time. I have a morning appointment and moving quickly to finish what I am working on right now. Hope that is not too late for you.
Thank you very much for your efforts; I'm not in a hurry
Best regards
Cool beenie weinies
Hi
I have done quite a large amount of printing from AECOSim and unfortunately there is no easy way to get just the skin.
I had a quick look at your stl. and it's pretty good. I think you might be able to get it to work if you make sure all of the openings are closed, at the moment there is a gap above your 'garage door', the roof light/skylight is open and so is the chimney.
Once these are closed you could try 'remove all holes' and 'extensive stitching' (both under Mesh fixes on Cura). This normally works well.
Oh thank you
I'll try it
I see @PaulMiles already got you the proper info I just got home so this was good to see.
you could try turning on 'print thin walls' found under shell tab in cura
Ok, but I'm planning my projects 1:1 and also windows and doors are in my CAD model in the real thickness. I also make all layouts and sections for 2D plotting from the 3D model, so it would not be appropriate to model them thicker.
SandervG 1,520
@Giuseppe Nagler You published your post in our 'international/global' part of the forum, where the main language is English. Could you write your next post in English as well? That way everyone can understand it who uses this part of the forums. If your English is not sufficient or if you just prefer to write in Deutsch, we also have a German forum. Feel free to use one/both of the forums for your questions. Thank you for understanding, and I hope to hear more from you!
