Posted · z-hop and retraction stringy
so right now i have travel settings in cura 3.2.1: z hop when retracted check, z hop only over printed parts check, z hop height 1mm.  i have material setting: enable retraction check, retraction distance 5mm, speed 40mm/s, retraction minimum travel 0.8mm
i get little string or tails that stick up when the nozzle moves in the z-axis during the hop.
it seems like there might not be anything i can do about this.  it's going to create the little tails no matter what huh? that's the nature of it?  the good thing about what i have set is that the nozzle won't hit the infill as it moves over the print.  any thoughts? or is there another setting i should be looking at?
thanks!
    ypu know, that could be it, the temp.  every now and then i think to myself i should try knocking it down 5 deg c.
    im a creality cr10s, hatchbox pla.
