There's a second good reason for this. The feature is called "horizontal expansion" and for pva support it defaults to 3mm.
While PLA sticks on top of PVA nicely it's not so good the other way around. So if you are printing something shaped like a 4 legged table where legs are touching the build plate (a stupid orientation but whatever) you don't need horizontal expansion - there's lots of pva to hold up the flat part of the table. But if you are printing a short tube with the hole being horizontal - the PVA doesn't stick well on top of the PLA inside this tube - you really need the PVA to be all connected together and to the glass plate to hold it all in place - so horizontal expansion has the PVA sticking out the sides of the tube by 3mm and then going all the way down to the glass.
This is a very crude feature that could be much smarter but it works for "most" designs.
nallath 1,125
Because of reliability. If you print very small bits of PVA, the PVA will remain above the degradation temperature longer, causing clogs. Combined with pva being less "study" as PLA, you need to ensure a min support size to ensure they don't get knocked over.
The default settings are a bit on the safe side, so in quite a few cases it should be safe to change it. You're looking for the support horizontal expansion setting.
As for the problem that you describe, that sounds more like a wipe problem (the nozzle oozing a bit when it shouldn't be printing)
