HI Geert 2,
thank you for this link and hint. But I don think that it adresses the real problem. It may be a good work around, but as you write - the blob is still there. The main problem I see is, that the material flow is stopped immediately and the print head is not immediately removed after end of print......the feeder is working still half a second after end and I never had this problem in the past. maybe Cura 3.2 is the root cause - or a change in the firmware with Cura 3.2... but maybe I am looking completely in the wrong direction.
geert_2 556
For such small items I always use this method (see pictures). If you make the dummy 1 layer higher than the real model, this method also prevents the blob from occuring on the models (they will be on the dummy, if any).
