I think you can do this with the new cura as well (cura 2.X, 3.X). You have to set infill to 0% and play with line widths (all of them - there are a few) and of course set wall thickness to a large value like you already did. Basically it's a lot of experimenting with wall widths and maybe also set flow to more than 100% - maybe 110%.
Thanks for the advice. I will fiddle around and report back.
- 2 weeks later...
I was not successful with the line width but finally "concentric infill" did the trick.
How do I mark the topic as solved?
1
You can mark it as resolved by editing your first post and adding the 'solved' tag.
On 3/12/2018 at 2:43 PM, UltiChris said:How do I mark the topic as solved?
I just marked it.
@Brulti - I'm a moderator so I don't know what it's like for regular users. I have to add the tag "solved" but *also* I have to make it a "prefix tag" so it shows up in the title in an obvious way both here and in the listing of all topics. Do you have the ability to do this on your own topics (prefix)?
@gr5 I do not see a way to 'prefix' a tag on my topics. There is no option for it. I've added the 'Solved' tag there:
It appears in the tag lists and the title, but not in the same obvious way like what you did on this thread.
Tha
On 16.3.2018 at 4:20 PM, gr5 said:@Brulti - I'm a moderator so I don't know what it's like for regular users. I have to add the tag "solved" but *also* I have to make it a "prefix tag" so it shows up in the title in an obvious way both here and in the listing of all topics. Do you have the ability to do this on your own topics (prefix)?
Thanks for the marking. As a normal user I can add the solved tag, but there are no further possibilieties to configure it or define it as prefix.
geert_2 560
In old Cura versions you could set the wall thickness to for example 5mm (at least more than your walls), and that would give the desired behaviour. I haven't used recent versions yet, but I think it should also be there somewhere?
