DidierKlein 729
Hi!
PP and adhesion is indeed complicated. That's why it's recommended to use the adhesion sheets (these work pretty well).
PP is known to stick to basically nothing so you can try different things but it's most likely it will fail.
Tips for adhesion as you probably know:
Large brim and pretty close levelling, you may want to change your first layer height to 0.2 or 0.1 for an extra squish.
Try blue tape maybe? But the best would be the adhesion sheets (you can buy that directly from your local reseller)
dxp 22
Hi @Tiger91,
luckily i could use those famous adhesion sheets from Ultimaker. And i printed a very small part. Lately i discovered some bubbles under the sheet where the corners of the part were - so, adhesion on the sheet was very good.
Maybe you could try something like book wrapping foil or Tesa 4309? I didn't test one of them but i would try if i had none of these UM-Sheets.
And maybe you could cover your UM with a card-board-box to keep the heat inside? Every bit of warmth helps :-)f
Cheers,
dxp
