tinkergnome 926
12 hours ago, Futz34 said:I've used the default travel speed of 120 and print speed of 50. I have retraction checked but I've never seen any customized settings for this.
If you use an UM2+ with Cura, the retraction settings are configured on the printer.
I would check the retraction speed and length. In newer firmware versions you find it here:
MATERIAL -> SETTINGS -> Customize -> Retraction
For 0.4 mm nozzle and PLA the defaults are 6.5 mm retraction length and 25 mm/s speed.
Tinkergnome is correct on those stats. Should I change anything to these settings or other settings? @SandervG
Edited by Futz34Bueller? Anyone?
SandervG 1,520
Hi @Futz34 , what are your retraction settings and what is your print and travel speed?
It would also help if you could add a photo of your stringy prints
