Cura Brim with Support causes path error
Tim Warren
Posted · Cura Brim with Support causes path error
Hi All,
I have an odd problem with the attached two parts. If I add a brim (only) and view the layers I get the expected 8mm brim on the first layer around the outside of the parts. However if I also ask Cura to also generate support, the brim becomes corrupt and results in only two circles around two points on one of the parts. I am at a loss as to why this is. I've attached the STL files, Cura project and screen shots.
I'm using a new install of Cura 3.2.1, however it is the same in 2.7 that I was using before today.
Any ideas?
Thanks
-Tim
Ball_Socket_LH.STL
Ball_Socket_RH.STL
Ball_Socket.3mf
Ball_Socket.curaproject.3mf.curaproject.3mf
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 13 replies
