Thanks for your response. I received my brand new Ulti PVA 350g spool and the difference is immediate.
A brand new good condition PVA filament is bumpy / rough to the touch, is cloudy and snaps. The used PVA I have is smooth to touch, almost completely clear / see-through and bends easily without snapping.
New PVA is on top
New PVA is to the left
gr5 2,094
I don't know all the answers. The flexibility is similar to pla I think - why - is yours very flexible?
The best way I know to test if it absorbed too much water is that it sizzles when you print (and you can also see steam coming out of the nozzle).
You want to keep PVA and Nylon extremely dry. I have dried nylon by setting the bed to 99C and letting it sit for 6 hours under a blanket on the bed.
However PVA will melt at that temp so you would have to do it closer to 80C I think - I'd take a snip of PVA, put it under a towel on the bed at 80C for 20 minutes then squish it firmly and see if it changes shape permanently - then repeat the experiment at a few other temps (I seem to remember it is soft around 80C). Then once you know what's "too hot" I'd heat the PVA for a few days on the bed under a towel at the highest safe temp. I'm not sure you can ever get the moisture out of PVA with the baking method but it's worth a try.
Ultimaker PVA is different than most manufacturers and takes much longer to absorb water (weeks). However I'm guessing (total guess!) this also makes it harder to dry.
