No more layer than 17
chamarejc
Posted · No more layer than 17
Could you post a link to the model you are trying to slice? And did you add any post processing scripts?
What about the cura.log? In Cura access the menu at the top "Help" and "Show Configuration Folder". There you should find the cura.log file. Take a look at the last few lines, maybe the error message helps.
    A model is very important to check out here. A screen shot would be helpful as it may be just that it got to a part too thin to sample and appears to have stopped slicing.
    It is ancient hoodoo.......
        • 6 replies
