Thanks for the files. I can slice that and get all the walls if I use a line width of 0.38 or lower but I am unsure of the print quality as it relies on the wall overlap compensation performing well which, unfortunately, it generally doesn't. If you disable the overlap compensation, it will try to print two lines where there is only space for one and if you enable the overlap compensation the width of the last wall to be printed will be higgledy-piggledy (technical term, aka pretty random).
The bottom line is that Cura really doesn't cope very well with walls that are an odd number of lines wide.
Hope this helps.
- 1
burtoogle 513
Could you make the gcode and the model available please so I can study them.
mechamecha 64
Definitely! Attached are the stl and gcode files generated from both Cura and S3D. Thanks!
bottle.stl
bottle_Cura.gcode
bottle_S3D.gcode
